- Mute
- Permalink
- Report
Hello I was running some tests with a toy problem to get a grasp of what can be done with rigid body connectors. This is a simplified problem of some more complex models that I've done.
The idea is to calculate this model:
This can be done easily simulating every piece. In the model the white and green bodies can rotate around the X axis. While this can be done, in some cases there is no information of the supports other than they should be much stiffler than the beam. The results should look something like:
I have tried to do the same using rigid body connectors. For that I set two small bodies that I restrict completely. I connected a corner of those bodies to the surfaces that were in contact with the supports. I have tried conecting just the appropiated degrees of freedom without success. Therefore, I tried to run the same model with all restrictions and all connected degrees of freedom. It seems to me that rotational degrees are not connected or I'm missing something.
Here it is the model and the results. In this case it shows a rigid body rotation around X:
