PLEASE PLEASE Help! Combining / Merging Issue!
Hi, I have just joined so am a newbie in the forum.  Exploring 3D printing and need some help please. How do I create a tapered 11mm slot hole,  26mm x 11mm (slot hole top), to 11mm (hole at bottom), placed 25 x 4 times (100 holes, 4 rows or 25 holes), exactly 14mm center to center of 11mm hole, side by side along the 25 hole axis, in a 30mm thick block please?
I would actually be happy with 1 correct hole in a small block at this point, and a way to duplicate it myself.
I can create the block, with round holes, and I can create the slot shaped hole separately, but nothing I can find to try so far is allowing me to do this in a way that puts that slotted out hole in the block.  I accept I am new but I have spent so much time for a couple of weeks watching videos and reading instructions, and I am clearly missing something. PLEASE HELP...
Block link below, if I have done it correctly.
https://a360.co/2Pb7wWV
Hole Link
https://a360.co/2PoqxoV
Thank you for your time in advance,
and have an enjoyable week.
Warmest Regards
Neville
jeevesme
Have you tried using the Rectangular Pattern command?
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
etfrench
First you need to make a solid hole, then you can use the Extrude|Cut tool to create the hole:
Note: Fusion 360 doesn't handle large patterns in sketches very well.  It's better to do the pattern in the solid model.
ETFrench
