Need help designing diff cover.
Message 1 of 12
Looking at making this diff cover. It is similar to the one in the picture. I am working in sheet metal because I want to cut the entire dome piece out on a cnc plasma cutter then bend it with my finger brake press.
The Issue i am having is filling in the gaps. I know they all need to be flanges so i can properly unfolt it, but can't get a flange to stretch the complex geometry.
Should I try designing this in another way such as in models?
Replies (11)
Message 2 of 12
The real part image you posted is 2 separate pieces of sheet metal and a separate blank for the drain plug.
There is a flange piece with the bolt holes, and then a folded piece that flares out around the diff.
Message 3 of 12
I agree, but I am having trouble making the upper part that wraps around., not the flange.
Message 4 of 12
melvinbrian3d
if you have the measures or share your .f3d file, upload here.
thanks!
MelvinBrian3D
Message 5 of 12
I would be glad to! Hope you have a good solution!
Message 6 of 12
dwoodville
I'm trying to do the same exact thing with a Ford 8.8 diff. Was there any solution to this as I'm stuck in the same spot.
Message 7 of 12
etfrench
Try it like this:
ETFrench
Message 8 of 12
dwoodville
Yes that's what I ultimately am trying but it is rather difficult to acquire the angles and everything that is needed.
Message 9 of 12
etfrench
Start by making a solid model.  This will give you the necessary angles and sizes.
ETFrench
Message 10 of 12
dwoodville
What tool would be best for a solid model? Lofting the corners doesn't seem to work.
Message 11 of 12
etfrench
Here's a crude screencast showing one way to do it.  Another way would be to use the loft tool.
ETFrench
Message 12 of 12
dwoodville
Thank you for the video showing how you did things. I'm working on it and will report back if I can make things work.
