Plane At Angle not behaving as expected?
I don't know if I'm doing something wrong or if this is a bug.
When I create a plane, I select a line, specify the angle (45 degrees) and the preview looks like exactly what I want.
But when I hit enter, the plane is rotated 90 degrees , and becomes perpendicular to the plane that I wanted.
wmhazzard
It works fine for me. Can you attach an f3d file of your model or a screencast showing the problem?
Sorry, I thought I had attached my screencast in my original post.
https://knowledge.autodesk.com/community/screencast/53a8512b-99d2-4d39-b950-f91a2c60a3f2
laughingcreek
that doesen't look right to me.  is this the only place it behaves like that (ie-doe it do that anywhere else in this model?  does it do it in other models on your machine?)
@jeff_strater  - thoughts?
Looks like it was a bug.
I tried it on about a dozen other lines and they all behave as expected.
Works fine in other documents too.
laughingcreek
If you can strip it down to a repeatable instance of this happening, AD would probably like to see it.  Helps with debugging efforts.
Okay I went back in history to where it was happening and was able to get it to do it again a few times. Seemed to be happening in only one part of a body.
What is the procedure to submitting this for Autodesk to review?
I've attached the .f3z file
(Sorry for the screencast, I'm very new to using a 3D mouse.)
