Pin-slot joint with curve and multiple directions
I'm super new to Fusion 360 - second day - and have designed up a plate that will be used to lock a bar into two rotational positions: 0 deg and 90 deg, and an extra pin to lock it in place at these two extremities. See screenshot and project link below.
I don't know how to lock the pins to their cutout pin guide. Any help would be much appreciated!
Cheers!
https://a360.co/2FHqeCZ
jhackney1972
For some reason, you model will not download.  I will keep trying.  In the meantime, take a look at this article and see if it helps you with your pin and slot design.
John Hackney, Retired
jhackney1972
I final got your model to download.  Practicing on another simple assembly, I have found out how to do a Pin-Slot joint on the basic curve, but your change of direction at the end, locking positions, I believe will require a different type of joint but I am not sure.  Take a look at the screencast to see how I would create a pin and slot joint for a simple curve.  As I say, I have no idea how to make it go around a corner.
Screencast will be displayed here after you click Post.
cf2755b1-46f1-4a56-9f74-00a1d5494ab3
Thanks for the link, I'll have a look!
I just downloaded the file myself, here's the download link if it helps. It will only last 7 days.
https://developer.api.autodesk.com/oss/v2/signedresources/73041a80-9c59-44e0-bb3b-dc6702ca508e?regio...
jhackney1972
I could not get my screencast to attach to my reply so I am posting it here.
Thanks for the info and time taken RE the pin-slot joint, definitely helpful. As you say though, my lock positions make this more difficult than I anticipated it being..
I found a video for how to do this in SolidWorks (I have a lot more experience in this, but they don't offer a hobbyist licence 😞 )
https://www.youtube.com/watch?v=2VBLB_sZ1I4  @ 3:20
