Trying to create/extrude at an angle
Hi new to fusion. I'm needing help making a rectangle that can be extruded at an angle. Cant seem to figure it out. I posted pictures to help identify where I'm needing the help as well. Thanks in advance!
davebYYPCU
Draw the braces in front view, Extrude front to back.
or you can Sweep a top view of the mitre cut, along the brace angle,
or you can sketch the rectangle on a Plane on a Path, (brace angle) then extrude two sides to object.
No right or wrong way,
Might help...
Thanks for the reply! Your suggestion definitely helped. I ended up creating an offset plane at the mitre and then used “split body” to create multiple bodies and then removed the ones I didn’t need.
