Patterned items in sketch no longer extrudable?
ianpmitchell
Message 1 of 12
ianpmitchell
Not sure if this is related to the changes to the personal license but I have just drawn a sketch, patterned some circles, saved the sketch and then went to extrude all of the circles but it will only allow me to select the first circle.
Is this a new "feature" or yet more reduction in functionality for the hobbyist, (Like "edit in place", now you see it, now you don't)
Replies (11)
Message 2 of 12
jhackney1972
I do not think so.  Please attach your model so the forum users can troubleshoot it for you.
John Hackney, Retired
Message 3 of 12
jeff_strater
nothing in this area was changed related to the Personal license.  Check whether you have profiles turned on:
and, as @jhackney1972 asked, share the design here.  Thanks.
Jeff Strater
Engineering Director
Message 4 of 12
ianpmitchell
Thanks for the quick reply John. I have never attached a model before so hopefully I have done it correctly
Message 5 of 12
ianpmitchell
Yes "Show Profile" is checked. I can see them in the extrude command, just can't select them.
Message 6 of 12
jhackney1972
When you patterned the hole, you select the center point "only" for your pattern.  Go back and edit the pattern and select the circle also.  I would recommend only Extruding one hole and pattern in the model instead.  Much more efficient.
Message 7 of 12
jeff_strater
I only see one circle in that sketch.  It looks like somehow only the center points were patterned.
I was able to create a new pattern, and all the circles seemed OK:
Jeff Strater
Message 8 of 12
jhackney1972
You have another problem which is preventing you from creating the extruded holes.  The bodies are only surfaces in your model.  This will give your issues.  Is there a reason you are using surfaces?
Message 9 of 12
jhackney1972
Attached is your model, by a different name, which I have stitched the walls of the canister together to make a solid and then extruded one hole through the wall.  Then I used a model Rectangular pattern to add the rest of the holes.  The rest of the model remains as surfaces.  I just wanted to show the efficiency of using model patterning as opposed to sketch patterns.
Message 10 of 12
ianpmitchell
John/Jeff,
Thanks for your help, it really is appreciated, that was a proper newbie error on my part, given I have been using Fusion for years I should have been able to sort it. I think all the angst going around about the recent changes to the hobbyist license I was too quick to think that was the problem.
With regard to the actual model it was an import of a .stp model from a supplier.
I have never used surfaces so I do not understand what you have done and why they should cause a problem.
What I wanted to do is then pattern the holes all around the body so that it actually looks like a strainer. I have downloaded your model John and have patterned the top hole around the body but I can't select the patterned extrusions of the other holes. Is this another function of the "Surfaces" issue?
I have included the model so you can see what I mean.
Message 11 of 12
g-andresen
in such cases I prefer the Pattern Type "Features" instead of "Faces".
Follow the screencast
günther
Message 12 of 12
ianpmitchell
Excellent Gunter, Thanks for the screen cast, that helped a lot.
Job done
