Path Patttern gets all messed up
Immedicale_Corpus
Immedicale_Corpus
I'm trying to get a simple path pattern of features. It works great in preview:
but as soon as I hit "ok" it becomes a hot mess:
Does anybody have any idea what might be causing that?
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Immedicale_Corpus
Here it is
jhackney1972
Pattern on Path has its issues.  I feel you best answer is to pattern the tubes as bodies and then Combine them into the base component.  Model is attached.  Please check my spacing.
John Hackney, Retired
Immedicale_Corpus
Thanks a lot, this worked!
g-andresen
Deviating from @jhackney1972  solution, I used the existing contour and moved the starting point of the pattern.
günther
