Create 4 sided profile for table pedestal
csbrads
Message 1 of 11
csbrads
I am trying to make a table pedestal that is square, I have the profile drawn and cannot figure out how to wrap the profile around all 4 sides.  I believe I should use the sweep tool but have not been able to get it to work.  Advice would be much appreciated.
Accepted solutions (4)
Replies (10)
Message 2 of 11
seth.madore
It would be helpful to see what you're trying to make, so either screenshots or the actual Fusion file would be greatly appreciated.
Oh, and this is a Design question, so I've moved this to the proper forum 🙂
Seth Madore
Message 3 of 11
csbrads
Here is a picture of what I am trying to maketable pedestaltable pedestal
Message 4 of 11
g-andresen
try it this way:
günther
Message 5 of 11
TheCADWhisperer
See Attached...
Dimension Sketch1 as desired.
Message 6 of 11
rushabhthakkar_910
You can also create this with Loft command..!!
(https://www.youtube.com/watch?v=cuqaT-lpT8c)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 7 of 11
Bunga777
I made it too.
The method of making it may be the same as others.
Prepare a square pillar of just the right size.
Draw the exterior curves using the canvas as a reference.
Cut out with Extrude by its profile.
Circular pattern copy is performed 4 times using the central axis.
Completion.
Click here to see a video of the series of work.
https://knowledge.autodesk.com/community/screencast/aaa89fa8-11a5-473f-be4c-4fb646154198
I have also pasted the data.
Message 8 of 11
csbrads
Thank you for your willingness to help.  This forum is Awesome
Message 9 of 11
csbrads
Awesome.  Thank you very much for taking the time to help.
Message 10 of 11
csbrads
Thank you so much for helping me.
Message 11 of 11
csbrads
Is there a way to save the video for future reference
