Parts List and Component Descriptions Missing
scotty71
scotty71
I am having a problem with parts descriptions showing up in the final assembly -and thus the drawings afterward.
Its worth noting, that the problem exists whether or not I use the drawings.
In image 1, I have a description that is working and carries all the way to the parts list when I draw.
Image 2 shows a base component with all its properties filled in
Image 3 shows what happens in the assembly.
I have set up each component the same, but it is only managing to hook ONE component.  Not sure why this has dropped - but it has.
I'm curious is this a MacOS Sierra issue/bug?
It's a curious one that I can't seem to find any tricks to work around it. Thanks!
_Scott
Mike.Grau
Hi @scotty71,
Thanks for raising our attention to that.
I could reproduce a similar behavior on my Windows 7 computer.
It just happens when you edit a description and save it to the cloud which takes a bit time
but updating your main assembly should show the description.
Could you may share your design with me via "Public Link"?
I might want to test if you see the same behavior in the offline mode, may break the link.
You can send me a private message if you would like to.
Thanks for your help,
