Parameters now from "driven" dimension is great, but why can't I use it in pattern?
1 REPLY 1
stiller.design
200 Views, 1 Reply
I just learned that now Fusion allows it to use driven dimensions for parameters.
I wanted to use those for making a body pattern, but very unfortunately that seems not possible. I can call the parameter, but its not possible to use it.
Is that a bug or a feature?
would be awesome if that could work IMHO
1 REPLY 1
hamid.sh.
in reply to: stiller.design
Unfortunately it's a feature at the time. Driven parameters does not work outside the same sketch (but Autodesk says this will be added in future... I hope it happens soon). So it's not just about body pattern, they can't be referenced for any operation outside that sketch.
Hamid
