Parameter Menu Pop Up ramdom sizes
joe
Message 1 of 15
joe
This might be a known bug, but I have to ask. My Parameter Menu pop up's appear in random collapsed sizes especially in Cam. For instance if I open an operation window and select anything other than the first tab the window becomes small and I have to use the scroll bar to see options. If I click the first tab first the widows after that are full size.  Windows 7
Replies (14)
Message 2 of 15
HughesTooling
The dialogs tend to work better if they are docked to the side of the screen. In the model workspace they work better if they're docked like this.
Dock the dialog on the right first then dock the Sketch palette to it.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 15
joe
It seems that there is more trouble with Cam pop ups. Take a look.
http://autode.sk/1QOkkzT
Im not sure if this screencast attached
Message 4 of 15
HughesTooling
I see the same problems if I dock the dialog to the left of the screen. I complained about similar problems in the model workspace a while a go and it was pointed out the dialog will resize if it's docked to the right side of the screen. Don't know when it will get fixed but it looks like resizing of undocked works better than it used to so they are working on it.
They still don't work well if you dock them like this.
Mark
Mark Hughes
Message 5 of 15
Hi!
I am new to Fusion360 and I have a small problem, lot of dialog windows are extremely small, and i cant move, or resize them.
an example here:
Is there any known solution to this?
I tried to dock it but as i said, i cant move it....
Kristof
Message 6 of 15
HughesTooling
Someone else did report this problem but they gave up and stopped using Fusion before the problem was solved, some people have no patients. @innovatenate Can you help.
Mark
EDIT, Does anything happen if you click the plus sign at the top of the dialog?
Mark Hughes
Message 7 of 15
Hi
I tried to click to the plus icon but it disappears when i move my cursor close to it...
I do micro-controller projects too and done some bug workarounds... i don't give up easily 🙂
Thanks for your help, i hope we find some solutions.
Kristof
Message 8 of 15
PhilProcarioJr
@Anonymous
What OS are you running?
Do you have a 4k display?
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 9 of 15
Hi!
@PhilProcarioJr:
I have a thinkpad t420 (NVS 4200m grapics card) with win7 and my external screen resolution is 1680 * 1050
Kristof
Message 10 of 15
PhilProcarioJr
@Anonymous
What do you have your font size set to in windows?
Phil Procario Jr.
Message 11 of 15
@PhilProcarioJr
100% smaller (default) if this is the information you need.
Sorry but my system language is hungarian by default. If you have any questions i am here.
Thank you for your effort.
Kristof
Message 12 of 15
PhilProcarioJr
@Anonymous
Try 125%
Make sure your video card driver is up to date.
Hmmm i'm out of ideas....
@innovatenate can you help with this one?
Phil Procario Jr.
Message 13 of 15
innovatenate
Autodesk Support
Autodesk Support
This looks similar to this forum thread.
https://forums.autodesk.com/t5/design-validate-document/dialog-box-too-narrow-to-read/m-p/6926297#M1...
Have you installed any custom fonts on this system?
Also, could you try the following steps?
1. Close Fusion 360
2. In Windows Explorer, browse to
C:\Users\***\AppData\Roaming\Autodesk\Neutron Platform\Options\***\
*** These folders will have custom names based upon your windows user account and your autodesk id.
3. Delete NULastDisplayedLayout.xml
4. Start Fusion 360 and retest
I hope that helps!
Nathan Chandler
Principal Specialist
Message 14 of 15
@PhilProcarioJr:
@innovatenate
Deleting the mentioned file, and restarting solved the problem!
Thank you for your help!
Kristof
Message 15 of 15
bacloss1
That worked perfectly.
Thank you so much.
