Desktop Layout
Desktop Layout
Desktop Layout
Little problem but irritating none the less.
When I drop out of the data panel the menu bar and the browser are left hanging in the middle of the work screen.  So I drag them back to the left side fo the screen.
Then I need to import something from another file and pop the data panel up and they are smack dab right over the files I need to open and they get moved back to the right.
Is there a function to attached these guys to the left side of the work screen?
Allan Steinkuhl
moto52000
I am having the same issue.  The menu bar is about 2" from the top and I cannot move it back.  When I opent the data pannel it goes behind the menubar.  Anyone know how to fix this?  It started after update today but also after I imported a file from grabcad.  Clues??Capture.PNG
jim_g
Try left click and hold ont the two little line in the model box the drag it up to the top and a green line should appear then release the mouse and the menu bar should dock there. Browser box should be the same
Jim Geib|Win 10 Pro|Intel CoreDuo 2.10GHz|4.00 GB Ram|ThinkPad LapTop
moto52000
That did it.  Thank you very much.  So many things are just frustrating when learning new software, should be simple like this but if your just guessing...
Wow,  that was easy when you know where to click. It might be good to point this out.  This is a well hidden feature.
Allan Steinkuhl
