Over-constraint problem
4 REPLIES 4
landslide1
571 Views, 4 Replies
landslide1
Hi
I'm trying fusion 360 out and comming from solidworks background.
trying to do a sketch starting from freehand lines then adding dimensions to the drawing to size and define the sketch.
the sketch has hardly any dimensions, yet when I try and use the sketch dimension tool to define an angle it wont let me. I get a error that the sketch is over-defined.
hopfully this link works to the scetch/model. http://a360.co/1NzFfnq
Hi
4 REPLIES 4
LMD001
in reply to: landslide1
LMD001
Hello landslide1,
In your sketch you have 2 tangent constraints on 2 arcs with the same diameter (upper right fillet +- 0,6 mm radius).
After removing one of the segments and extending the other, ending up with the same geometry only now with 1 arc, the sketch is no longer fully constrained.
Not entirely sure why this happens.
Hope this is of any help.
Best regards,
Ludo
Hello landslide1,
Best regards,
Ludo
sachlene.singh
in reply to: LMD001
sachlene.singh
landslide1,
I can replicate the same behavior. Can you confirm that once you convert those two arcs to one single tangent arc, the problem goes away?
Thanks LMD001!
-Sachlene
landslide1,
Thanks LMD001!
-Sachlene
landslide1
landslide1
thanks for the solution.
I removed one of the arc segments and dimentioned the other. then I added the second arc and dimensioned it and now I can continue defining the sketch.
I left 2 arcs as one was supposed to be 1mm and the second 0.5mm.
LMD001
in reply to: sachlene.singh
LMD001
Hello Sachlene and landslide1,
No problem. Happy to be of any help.
Best regards,
Ludo
Best regards,
Ludo
