Option for "Objects to Join"
When performing extrudes or Boolean operations of different shapes there is no drop down to select what objects are joined, compared to performing a cut operation you can pick which objects/parts to cut.
This forces user to join everything (not a good solution) or create a new body, then have to do perform a second operation to combine the desired bodies, this would be much more efficient to have the same drop-down as the cut operation and eliminate the need for a combine operation afterwords in many cases.
