Option for "Objects to Join"
joelgHHWQD
joelgHHWQD
When performing extrudes or Boolean operations of different shapes there is no drop down to select what objects are joined, compared to performing a cut operation you can pick which objects/parts to cut.
This forces user to join everything (not a good solution) or create a new body, then have to do perform a second operation to combine the desired bodies, this would be much more efficient to have the same drop-down as the cut operation and eliminate the need for a combine operation afterwords in many cases.
Marco.Takx
Hi @joelgHHWQD,
You have to work with #Rule 1, Make components
You are speaking about parts in you're screenshot. And that is what components does.
one part can be more bodies.
So making components of each part will bring you to your needs.
Fusion 360 #Rule1
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
joelgHHWQD
Yes I understand that, but that still creates the need for a second operation if you are trying to make one part from multiple bodies inside of a component. Also, why would we then have the option under cutting but not joining as the same argument could be used for cutting?
TrippyLighting
I would support this improvement request. The tool appears not fully implemented!
