Objects colors of some of my profects are gone after installing Fusion on new PC. Project colors are saved on Appearance tab tho. I used to install Fusion 360 on different devices and everything was fine. How to return colors back? The pictures attached.
Solved by emelyanovich007. Go to Solution.
Solved by Drewpan. Go to Solution.
Off the top of my head, the most likely reason for that behaviour is that you are using materials and colours that you
may have downloaded from the online library that were not installed on the default install of fusion. It may be as
simple as looking at the materials on the machine that works and then seeing if those same materials are being used
on the new machine or if it is defaulting to Steel.
Cheers
Andrew
