Object visibility save event & derive components/objects
bwalker145
bwalker145
Why does showing/hiding components force a save event?
When I have to hide components in an assembly, in order to find internal objects for derive, Fusion forces a save of the assembly before the derive command, even though no changes have been made to the components. Not a big issue, I'd just like to avoid unnecessary save records when a design is already at a mature level.
"Why don't you just select the derive object from the browser?" - Internal designs that I created and know the file-structure/naming convention work fine with this, but I also have to import customer-provided files where the naming structure doesn't import correctly 90% of the time. Large assemblies are also a pain to scroll through on the browser, vs. just physically finding the object and using "isolate".
jeff_strater
"Fusion forces a save of the assembly before the derive command, even though no changes have been made to the components"
Ah, but that is not really true.  Visibility is persistent, so a change in visibility is a change to the design.  If this were not considered a change, then we would get complaints like:  "I set up my component visibility just how I like it, and closed, but I was not prompted to save, and all that setup is lost".
Jeff Strater
Engineering Director
bwalker145
Fair enough, and I'm sure their complaints would far outnumber mine. I have noticed object visibility impacts base views in drawing creation, although whether or not the object is actually suppressed isn't very consistent for me (I usually notice when the creating the part's list). However, that just may be the difference of me hiding objects with "V" vs. toggling at the component level.
