Emboss on sphere bug
danielpoulsen1984
Message 1 of 55
danielpoulsen1984
I am doing some work with semispheres and banging my head against the wall when it comes to accuracy on my embossed sketches and then I tried to simply emboss a 25mm circle on a 28mm sphere and the result is quite perplexing. Instead of delivering a clean round emboss, it becomes a wavy mess. And this is the same I am seeing in my other emboss results, when trying to emboss a circular design on the semisphere.
I can do some workarounds with using split face and others when it comes to simple design, but for more complex sketches(text in a circle for example), I don't see a workaround as of right now.
Replies (54)
Message 2 of 55
TheCADWhisperer
@danielpoulsen1984
What are you attempting to model?
This looks like a simple Revolve to me.
Message 3 of 55
jhackney1972
Create your sphere with a Revolved Semi-Circle and your will get better results.  Model example attached.
John Hackney, Retired
Message 4 of 55
danielpoulsen1984
Hey John, thanks for the quick reply, but that unfortunately doesn't change anything.
Message 5 of 55
TrippyLighting
Frist, I would not use a sphere primitive. Then I would not use the move tool either.
See the attached model.
Message 6 of 55
danielpoulsen1984
It doesn't actually change anything adding a semicircle around it. The example you just uploaded also has the same flaw:
The bigger you make the sketch compared to the circle, the worse the distortions get.
Here the circle is 50% bigger:
And 100% bigger:
So to me, this is a clear bug and should be reported to devs.
Message 7 of 55
danielpoulsen1984
My designs are much more complex, some even containing text and can't be handled by simply using revolve. Think logos on a sphere.
Message 8 of 55
jhackney1972
There is a limited to the size of the sketch you can use to wrap around the sphere.  In the attached screen capture I have a 200 mm diameter sphere and a 250 mm Embossed Circle, it is getting a little flaky.
Message 9 of 55
TheCADWhisperer
Then let's move on to the true Design Intent.
This one was a simple Revolve.
Message 10 of 55
danielpoulsen1984
Hence me reporting this as a bug 😁 It’s clear that the emboss is not wrapping the sphere correctly and some development power is needed to fix this.
Message 11 of 55
danielpoulsen1984
I can’t divulge the exact information as I am working on a startup. But think regular circular company logos. I need them to wrap halfway around a sphere at max and I can’t get the emboss tool to work correctly as shown in the above posts. This is the reason for my post.
For simpler design I can do hacks with centering the design in chunks or using the regular tools like revolve etc, but alignment is then almost always an issue.
Message 12 of 55
TrippyLighting
Then I would suggest you post relevant examples not dumbed down stuff!
Message 13 of 55
danielpoulsen1984
The example is relevant to show the bug I am reporting….. even if “dumbed down”.
Message 14 of 55
TheCADWhisperer
@danielpoulsen1984
Make up a dummy file that exhibits the same behavior as your proprietary data.
Message 15 of 55
danielpoulsen1984
Imagine the letters curved perfectly in a circle, these are just quickly typed in and moved to the edge of the sketch to emboss down on the sphere. But it is clear to see that the logo which is circular isn't embossed with a straight curve, hence the logo looking "wonky" and the text alignment as well.
Message 16 of 55
TrippyLighting
Agreed, and reporting a bug is appreciated! (this one is known and has been reported on the forum previously @Phil.E )
However, you'll have to work around it and an example representative of what you are trying to achieve is going to be helpfull.
Message 17 of 55
TheCADWhisperer
@danielpoulsen1984
The sketches do not meet my quality standards, and I doubt I would use emboss function for this design.
I doubt I would use a Sphere primitive, and don't see a need for a Move.
Message 18 of 55
danielpoulsen1984
I am a novice in using the product and I am not even sure what you are saying, but thank you for sharing your insight.
Message 19 of 55
TheCADWhisperer
I am a novice in using the product, but thank you for sharing your insight.
That is what I suspected which means it will be all the more difficult to decipher the true Design Intent and help you arrive at a solution.
It may take several days of back-and-forth discussion.
Message 20 of 55
danielpoulsen1984
I can do it with a “hack-ish” approach, but in reality, I am just looking to report this bug and have it fixed, so I can work with the product as intended.
As said, I am a novice and just getting into this, but I am not going to buy a license when my current primary use isn’t even working as intended, causing me to spend hours upon hours manually aligning things and getting a less than perfect result.
If you feel like there is a better way to do this, feel free to share some pointers, I don’t mind spending hours to learn, but I’m running out of ideas to search for in regards to this issue.
