Object visibility save event & derive components/objects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Why does showing/hiding components force a save event?
When I have to hide components in an assembly, in order to find internal objects for derive, Fusion forces a save of the assembly before the derive command, even though no changes have been made to the components. Not a big issue, I'd just like to avoid unnecessary save records when a design is already at a mature level.
"Why don't you just select the derive object from the browser?" - Internal designs that I created and know the file-structure/naming convention work fine with this, but I also have to import customer-provided files where the naming structure doesn't import correctly 90% of the time. Large assemblies are also a pain to scroll through on the browser, vs. just physically finding the object and using "isolate".
