Emboss Feature Calculation Error
jeffescott
Advisor Advisor
Message 1 of 13
jeffescott
I had problems getting the correct length of a bent spring.  I checked and find that Fusions bending routines are out by some 3 to 9% based on volume changes (and hence mass changes) between the straight spring and the bent spring....this error carries through to the predict length after bending.
This is based on the emboss method of bending the spring.
The volume of half of the the spring before bending is 3014.351 mm3.  The volume of the half of the bent spring is 3127.583 mm3. This is an error of 3.76%.
I also bent the spring using a sheet metal method. The volume of the spring before bending is 3014.352 mm3.  The volume after bending is 3294.069 mm3.
This is an error of 9.3%.
Please note that the error, close to the error I have to adjust the length to get a correct result after bending. This is shown in Component clamped spring:1.
Below is a description of the emboss method I used.
I have created a body of a spring I wish  to bend. Component=( Half Spring spring:1) Body= (half spring (1)).
I then create a body of the xz profile I wish to bend it to Component=(emboss spring:1) Body=(EMBOSSER)
I then create a projection of this body in Component= (emboss spring:1) Sketch= (profile).
I then emboss the profile on the embosser, split the body, mirror it and I have my spring.
Replies (12)
Message 2 of 13
TheCADWhisperer
@jeffescott
I must admit that I am completely confused by your workflow.
I would model in finished form exactly the dimensions required by the customer.
Then I would work backwards to the Flat Pattern k-factor.
Let me look at this again to see if I can decipher the true Design Intent final dimensions.
Check back.
Message 3 of 13
jeffescott
Yeah I got this method from the forum two elite members trippy suggested the sheet metal way and JRH suggested the emboss way ...the sheet metal rule uses a K of .44 and results in the higher error.  If you have a better way i am all ears.
Regardless the volume change should not occur regardless of the k.  I am sure no metal fell of the part when I bent it.
This Ti g5 is heated to cherry hot and bent.  The resulting oxide layer is just beyond dark blue.
Message 4 of 13
TheCADWhisperer
@jeffescott
As I get started - this is the only geometry that matters to me at the start. The geometry as it is in the assembly, the geometry that the customer (internal or external) is paying for.
The geometry that goes through inspection to meet print specifications.
Message 5 of 13
TheCADWhisperer
@jeffescott
First, I identify - what are the critical dimensions for your component to function in the assembly?
The inside dimension or the outside dimensions (everything else will follow those dimensions)?
Message 6 of 13
TheCADWhisperer
@jeffescott
There should never be two sheet metal bodies within a single component.
If for some reason you need to model with multiple bodies you model as standard and then Remove extra body and Convert remaining body to Sheet Metal.
Message 7 of 13
TheCADWhisperer
When you bend sheet metal the material stretches on the outside of the bend and compresses on the inside of the bend.
The neutral "plane" where there is no stretching or compression generally isn't halfway through the material, not the midplane.
The amount of stretching is dependent on the material properties, thickness, bend radius and bend angle as well as tooling used to create the bend.
Fusion will calculate the stretching to give you the correct Flat Pattern Length (based on k-factor or Bend Allowance (I have to check to see if Fusion has Bend Tables)).
Fusion does not calculate the thinning of the bend stretch area to return correct volume in both formed and flat pattern condition.
Message 8 of 13
TheCADWhisperer
@jeffescott
Fusion assumes that the Bend Radius (inside radius) is the same as the Thickness.
If different Bend Radius is used - you must specify the value.
Message 9 of 13
TrippyLighting
The K-Factor determines where the "neutral fiber" of your bent object will be. Material to the side of the neutral fiber will compress or stretch. That is associated with a change in volume.
The K-Factor is an approximation,  a starting point. It can and perhaps should be adapted to the specific situations/materials. That is especially the case when the material is heated to high temperatures.
Message 10 of 13
TheCADWhisperer
@jeffescott
These are my starting dimensions based on the inside dimensions of your part.
Do you have an expected Flat Pattern length, and if yes, how did you arrive at that number (remember the Flat Pattern will be shorter because the material is stretched when bent).
You can't simply add up the straight lengths and the arc lengths (in fact it is longer on the outside of the bend than thin inside of the bend because the outside arc is longer).
There is a formula in the Machinery's Handbook that shows how it is calculated.
Message 11 of 13
TheCADWhisperer
@jeffescott
What is the name of the sketch for this geometry?
I tried to find it but gave up.
I tried to dimension myself, but the dimensions did not make logical sense, so I need to identify your sketch so that I can see the dimensions that you used.
Edit: Never mind, I finally found it.
Message 12 of 13
TheCADWhisperer
@jeffescott
Not sure why a solution was marked?
Examine the Attached file.
Indicate any dimensions that I have out of spec.
I modeled as Sheet Metal with several simple sketches to avoid confusion of a complex sketch.
No need to duplicate work.
Message 13 of 13
jeffescott
Accepted solution because that solved my issue with the errors.   Done simply it all works out.   I will review your file, and learn alot im sure.  Thanks for your time and effort.   Waiting on material so i have time now.
