NOT BEING ABLE TO DELETE
Message 1 of 10
WHAT DOES IT MEAN WHEN I SELECT AN OBJECT BUT IT WILL NOT DELETE
Accepted solutions (3)
Replies (9)
Message 2 of 10
martin.zatecka
I'm not sure what is exactly your situation. I prepared a short video with examples of how to delete a component or body.
In modeling when using body, it's not possible to delete only one side of body. You can delete certain parts of body, but the result must be again solid body.
regards
Martin
Martin Zatecka
UX Designer
Message 3 of 10
jeff_strater
Hi stewartryrie,
A quick question for you:  Are you trying to delete an entire Fusion design from the data panel or A360, or deleting objects from within the Fusion modeling application.  If it is the latter, what types of objects were you deleting, and what error message, if any, did you get when you deleted the object(s)?
To clarify Martin's response:  You can, actually, delete some faces from a body, from the Patch workspace:  http://autode.sk/1zyZKNL
However, and this is just a guess, were you trying to delete an entire body by selecting all of its faces?  This is a common problem in Fusion.  It really has to do with the type of objects selected.  You can delete faces, (for instance, you can delete a hole by selecting all of its faces).  But, if you select all of the faces of an entire body and delete, Fusion will try to delete the faces one at a time, and this doesn't work.  If you want to delete the entire body, the best approach is to select the body in the browser and delete from there.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 4 of 10
Can you open my sketch? if so you will see a block and at the top is a slit. There are 2 circles one on each side of the slit which when i select and try do delete them nothing happens. Why?
Message 5 of 10
jeff_strater
Sorry, no, I don't have access to your model.  Can you post it here, or share it with me?
Jeff
Jeff Strater
Message 6 of 10
I could not read the selections you made on the left side of the screen
Message 7 of 10
martin.zatecka
It was right mouse click at component item (selected in browser)
Does it make sense? Do you mean something else?
regards
Martin
Martin Zatecka
UX Designer
Message 8 of 10
I have had problems deleting sketch elements since day one. Why can't I delete a rectangle after drawing it?
Does anyone understand why this is not possible?
Here's my work flow in Fusion 360...(approximately 10 minutes)
1) draw rectangle
2) delete rectangle, but it fails, try again and again
3) try again until I eventually close Fusion and use a better CAD program
4) post here because it doesn't work hoping someone can explain how to delete a rectangle
And here's my work flow in Rhino...(approximately 10 SECONDS)
1) draw rectangle
2) delete rectangle
Message 9 of 10
jeff_strater
When you say "rectangle", do you mean a sketch rectangle, like this:
Or a 3D solid block, like this:
Either should work OK, but they are different operations.  Would it be possible to post a screencast or video of your workflow in this case?
Jeff Strater
Message 10 of 10
I am a beginner at Fusion and I just had the same problem of not being able to delete a very basic geometry I had created. I found out that the reason I could not delete was I was still in sketch mode. I think this is something only a beginner could do so for all you beginners out there I hope this helps!
