Not all digits of value showing while dragging size in sketch
janus2
janus2
First digit not showingFirst digit not showing
Hello!
If i drag a circle for example I can not see all digits. Should display '11.23'. The first '1' is not visible. I tried to remove the 'millimeter' text in preferences without success.
I think the display box is too small.
Do I have a chance to improve here or do I have to wait for Autodesk.
Jan
HughesTooling
Go to preferences and check Display abbreviations for units. Note you'll need to close and reopen the sketch to see the change.
Mark Hughes
Owner, Hughes Tooling
janus2
Thanks a lot. That was the trick!
Jan
chrisplyler
Also, just in case you don't already know this (unlikely, but  just in case), you can just type the exact value you want into the field.
