To simplify my problem as much as possible, I have a surface with a sketch pattern on it. While changing the size of the surface using model parameters the pattern entities should remain the same just their number has to change and I need to add an appearance to it (would say I need split face too for each one of them). I understand this can be solved using scripts but I am not that proficient at programming so I was thinking if there was a way around this.
P.S. I don't even know how to define this problem in Fusion 360 for the number of pattern entities without using a division without a remainder.
