Finding Midpoint of a Control Point Spline?
jeffdbeats
jeffdbeats
Looking to find the perfect midpoint of this spline. How do you do this in Fusion360?
Jeff
davebYYPCU
Work Point on the Path, at 0.5 (or 50%) and
Project it to the sketch.
If needing a sketch normal to that path, just use Plane on Path.
Might help...
jeffdbeats
Thanks Dave! This worked great... Never knew about that option, found it under construct tab.
Jeff
davebYYPCU
To be honest, it arrived in the last major update as a new function.  Tested and worked here.
