Hole with threaded ends, not center?
I'm new to 360 as you might tell by this question. I've looked and can't seem to find the answer. How would I go about creating a through hole with two threaded ends and not the center portion?
I thought about creating a cylinder, but then run into the same issue with threads on either end, then using that to cut the block shape that I have.
Any suggestions would be welcomed.
jhackney1972
i would suggest creating an extruded hole and then using the Thread command on each end.  See screencast.
John Hackney, Retired
Awesome! Thank you that does help.
johnswetz1982
Mark his post as the solution if it was so that others can find this.
