Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Non-manifold problem
1 REPLY 1
chunk07
686 Views, 1 Reply
I am working on a customized banjo for the change gears on my lathe. By changing one dimension, I can customize the banjo for different gear sets. I have successfully printed 2 versions of this part, but the 3d, and biggest, when sent to Repetier Host, pops up a warning that the model is non manifold.
I have opened the .stl for this version in Meshmixer, and try to repair the mesh, it removes parts that were not affected by the dimension change. What am I doing wrong?
1 REPLY 1
chunk07
in reply to: chunk07
Disregard, fixed with patch.
