Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Connecting two arcs of different sizes
1 REPLY 1
martinjlane
397 Views, 1 Reply
I am creating an arched roof with roof panels connecting each arc, this works fine when the arcs are the same diameter, however I now want to create a panel that connects two arcs of different diameter. So effectively twisting the panel and altering the arc at each end of the panel.
The objective is to re-create the entrance roof to Paddington Station in London. This has a small arch entrance which is offset to the left and tapers to a lager arch within the Station roof. I have attached a photograph of the entrance so you can see the issue
1 REPLY 1
This should be a relatively simple problem - but I notice quite a few issues in your timeline.
Before taking on a project like this:
I think I would post a question at first occurrence of any issue (and include file attachment) rather than continue on creating additional issues.
