no revolve
no revolve
magpiemachining
no revolve
magpiemachining
revolve not working? something get changed? sculpt is gone also. what am i doing wrong? i used revovle when making a pulley and other jobs but not working today.i can pick the origin but not the profile. i has angles and radii and thouhg that may have been the problem. removed them all still cant select profile. thank you
daniel_lyall
@magpiemachining Sculpt is only there if you turn the timeline off or select create form under the create menu, revolve in the Sculpt will only show up with what I have already said.
Revolve in the Model and patch are there with the timeline on or off.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
magpiemachining
  i dont remember turining the timeline on or off. i dont know if it is on or off right now. i dont know how to turn it on or off. when i opened fusion this is what is happening. i may have did something by mistake.
daniel_lyall
Have a look at the attached screencast
Daniel Lyall
The Big Boss
Mach3 User
SaeedHamza
What @daniel_lyall is saying is that he's referring to the direct modeling mode ( that's when you turn off the timeline )
Now for the revolve thing ... as I understand from you, the revolve works fine with the origin axis selected, but when selecting the profile it doesn't work
Now could you please provide a screencast or at least a screenshot showing the axis you're trying to pick
Regards
Saeed Hamza
TrippyLighting
The reason you cannot revolve the sketch is because the sketch profile is turned off, probably by accident. The first time this happened to me I had a meltdown that would make Gordon Ramsay blush!
If you right-click on the first sketch and select "Show profile" the yellowish inside of the sketch will return and then you can revolve it.
magpiemachining
that was it!!! thanx trippy
