no results measuring a mesh object
stiller.design
Message 1 of 20
stiller.design
Anyone else has the same issue, not being able to measure a mesh ?
I don't get any results and it puzzles me....
(view in My Videos)
Replies (19)
Message 2 of 20
g-andresen
works for me
1. try another file
2. quit fusion360 and restart again
günther
Message 3 of 20
TheCADWhisperer
@stiller.design
Message 4 of 20
stiller.design
I open this 3mf file , but I can't measure anything. it works though when I create the mesh in Fusion 360
PS: had to zip the 3mf file, wouldn't let me upload it otherwise
Message 5 of 20
stiller.design
restarting did not make a difference
Message 6 of 20
TheCADWhisperer
@stiller.design
Is the part supposed to be symmetrical?
Message 7 of 20
stiller.design
I am trying to measure it , it should be symmetrical but I am not sure why that is relevant for measurements
Message 8 of 20
TheCADWhisperer
Is the part supposed to be elliptical?
Triangular faceted mesh is rubbish - not sure why you would try to measure it?
Message 9 of 20
stiller.design
I want to measure it and it doesn't let me do it. It wasn't a question about how awesome the triangles might look like.
Message 10 of 20
stiller.design
the INSPECT (i) tool is not working @TheCADWhisperer
Message 11 of 20
g-andresen
The measure tool does not have a snap function for mesh objects.
After conversion to solid, however, it works between surfaces, points and also for lines.
Since I don't deal with imported meshes, I can't say if it ever worked.
günther
Message 12 of 20
stiller.design
that is not true , you can measure mesh .... look at this:
this is a mesh and measure works here
Message 13 of 20
HughesTooling
I don't have any problem measuring your mesh. Not sure if I have the latest version of Fusion though, haven't shutdown for a few days.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 14 of 20
g-andresen
that´s what I see
(view in My Videos)
günther
Message 15 of 20
HughesTooling
@g-andresen Although you get better results and measurement after conversion you did get a dimension before converting. If you look at the OPs video in the first post they don't get a dimension at all.
Also with orthro views you do seem to get a snap to vertex points.
Mark Hughes
Message 16 of 20
stiller.design
I am running the same version. the strange thing is when I export a file to 3mf and import it I can measure it. but not with this file. Thanks for your help
Message 17 of 20
HughesTooling
@stiller.design  Yes, something odd about the mesh in your file, I can't get measurements off the mesh either.
Have you got the original mesh file? Can you share it here?
Thanks Mark
Mark Hughes
Message 18 of 20
g-andresen
In some tests I found that the measurement function only works if only the STL format was used for the imports and exports.*.
But, wherever, 3mf was involved, the (defined) measurement is no longer possible.
For this purpose, the file name is not taken over when importing 3MF (in contrast to STL).
* In later attempts, however, it no longer worked even with "pure" STL files.
günther
Message 19 of 20
stiller.design
@HughesTooling that is the 3MF file
Message 20 of 20
stiller.design
@HughesTooling could you find any issues?
