texture map screwed up
SEIZMICdesign
SEIZMICdesign
opened a model just now and the texture map is all screwed up. Was still set to cylindrical, around the correct axis, but it just looks all screwy. Literally.
In the attached screen grabs, the sides are supposed to (and did last time I had the model open) look like the bottom surface.
RyanCameron
This might not solve your issue but I'll take a swing at it. If you wouldn't mind, please hit the like button if this at least gets you closer to your goal.
  1. Click the "Appearance" icon in the toolbar on the right-hand side of the screen. This will open the Appearance panel.
  2. In the Appearance panel, click on the "Texture" tab.
  3. Select the texture map you want to adjust by clicking on it.
    1. At this point, just mess with the settings until you start getting closer. After a certain point you should start to see whether or not the adjustments you’re making are heading in the right direction.
    2. Then utilize the sliders under "Texture Properties" to make adjustments to the texture map settings. I suppose you can adjust the brightness, contrast, hue, saturation, and other parameters too.
  4. Preview your changes in the "Preview" window on the left-hand side of the screen.
  5. Once you are satisfied with the changes, click "Apply" to apply the new settings to the texture map.
Plan B. Completely start from scratch. Off to the side recreate the object and apply a new texture map that has been resized.
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
TrippyLighting
I'd like to take a look at the model if possible.
