Newbie with a suspension simulation/analysis question
mcw0
Advisor Advisor
mcw0
Hi Everyone,
I am new here and new to Fusion 360. I'm here because I want to test out some ideas. But before I get too far into building a mockup, I want to know if I will be able to get useful data from an analysis of my design. One example would be spring rate. If I model a spring/shock absorber, will I be able to set a spring rate and then load the structure to see if the rate needs to be adjusted?
Manny
John_Holtz
Autodesk Support
Autodesk Support
Hi @mcw0 . Welcome to Fusion.
The Simulation environment does not have a spring element. That is normally how springs are added to an analysis where the spring rate is a numerical input. Without that element types, you would need to physically model the spring which is not a very efficient method.
Another potential issue is what type of analysis do you want to perform? "Suspensions" and "damping" typically imply some type of vibration or dynamic analysis. Fusion does not have analysis types such as random vibration and frequency response which would normally be used for those types of designs. (Fusion does have the event simulation, but that is not designed to handle the typical vibration problem.) If your problem is static, then the static stress or nonlinear static stress may be suitable for your analysis.
Please feel free to provide more details about what you trying to simulate and what effects you are including.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
mcw0
Hi John,
I was going to try simulating/analyzing a suspended mountain bike.  Just curious what kinds of information I can get out of Fusion.  For instance, if I place a 100lb rider on the structure, what spring rate would the software lead me to?  And what happens if I double the load.  Just my curiosity and playing around to see relationships in systems.  I'm not an engineer.  Just a hobbyist.
TheCADWhisperer
You can do this in Autodesk Inventor Professional - Dynamic Simulation environment.
Students can get Inventor Professional for free.
mcw0
Thank you.  I will check out Inventor.
