New sketch color scheme :-((
kristianY3VSG
2.935Aufrufe
19Antworten
Nachricht 1 von 20
kristianY3VSG
could anybody explain please the sence of making visibility worse? Now it´s nearly impossible to distinguish sketch profiles among bodies (do you see them in the screenshot?), and the difference between projected lines and body faces is very poor too.
The change to the new function icons some time ago was rather negative too, the old icons were easier to distinguish in the timeline. Why was all this done???
How can I switch back to the old sketch color scheme? Couldn´t find any setting...
Kristian
2.936Aufrufe
19Antworten
Antworten (19)
Nachricht 2 von 20
etfrench
Autodesk doesn't have any old programmers with poor eyes 🙄
ETFrench
Nachricht 3 von 20
kristianY3VSG
0 „Gefällt mir“-Angaben
Nachricht 4 von 20
jeff_strater
I am all 3 of those things:  old, programmer, bad eyesight.  You forgot one attribute:  Uses an environment other than Photo Booth.
I used to use Dark Sky, but I bowed to the will of the Photo Booth enthusiasts, so I didn't see this.  That is also why I didn't notice that the larger range of component color cycling colors is only available in Photo Booth 😞.  I've notified the sketch team on this one, hopefully they can comment, and hopefully address this.  I'm sure there is an XML file somewhere that has this in it, should you want to tweak it on your own, but that has always seemed like too much effort for me.
Jeff Strater
Engineering Director
Nachricht 5 von 20
laughingcreek
@jeff_strater -as long as your passing things on to developers (this ones in photo booth)-
Nachricht 6 von 20
lichtzeichenanlage
And if you're going for an overall color pallet, please don't forget a full dark mode (not only one canvas).
Nachricht 7 von 20
jeff_strater
@laughingcreek - I can't reproduce that photo booth problem.  Those are construction lines, right, or CV curve polygon lines (same thing internally)?  How did you get them to totally disappear?  Yeah, that's a problem all right, if we can reproduce it.
Jeff Strater
Nachricht 8 von 20
laughingcreek
This doesn't happen for regular construction lines. This happens for fully
constrained control line for the CV spline.
Nachricht 9 von 20
jeff_strater
weird.  I don't see that.  Here is what I think is a fully defined CV spline in Photo Booth:
Now, Dark Sky definitely has a problem:
Jeff Strater
Nachricht 10 von 20
chrisplyler
You guys should quite letting Chad upload his work into the "for release" folder without it being double checked.
Nachricht 11 von 20
laughingcreek
Jeff- I don't know what conditions causes this to happen.  I thought it was just having the sketch be fully constrained, but apparently it's not just that.  I managed to reproduce it, but the order that constraints and or dims are applied  seems to makes a difference.  in this example, the last dim I applied was the vertical 22mm one, at which point the control frame turned white. see attached and below pic.
Nachricht 12 von 20
MichaelT_123
Hi Gentlemen,
I like wandering in the forest particularly in the autumn season with a plethora of soft colors, but in CAD systems hard color contrasts are desired. Reading this thread and many others, it seems that ADSK.CORE member(s) also longs for natural colors.
Going to the point. There is logical function XOR which for well over 50 years has been utilised on pixel's graphics to optimise color(s) contrast(s).
Perhaps, it could be worthwhile to look at its potential.
Regards
MichaelT
MichaelT
Nachricht 13 von 20
laughingcreek
@jeff_strater - just in case it got lost in the shuffle, check post 11.  Some kind of bug.
Nachricht 14 von 20
jeff_strater
thanks, @laughingcreek .  Created FUS-58465 for this.  Strange thing is, the control polygon is there, it is just drawn in white.  You can see if you look closely that the lines are there, they are just drawn in white:
this is more obvious if you switch to a darker environment:
also, if you add any new geometry, those lines are updated correctly:
Anyway, we'll let the sketch team take a look at it.
Jeff Strater
Nachricht 15 von 20
kristianY3VSG
Please don´t forget about the primary topic in message #1:
The new sketch color scheme is really bad, and the 2px wide lines as well.
If you insist on this scheme, please add a preference setting for alternative use of the old scheme!
Kristian
Nachricht 16 von 20
Nicht anwendbar
Seconded! I find the sketch color options in all existing environments to be less visible than the old color scheme in Photo Booth.
Please add an option to adjust sketch colors, or at least the ability to toggle back to the old scheme.
Nachricht 17 von 20
daniel_lyall
That's an Apple one what would be good @jeff_strater  ???? when
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Nachricht 18 von 20
lichtzeichenanlage
WHy is this an Apple one?
Nachricht 19 von 20
Nicht anwendbar
I've been away from Fusion for a few weeks and this was an unpleasant surprise on my return.
I use photo booth environment, and have young eyes.  This new color scheme is terrible for productivity.  Modifying sketches while bodies are visible has become a chore.  I'm being forced to alter my workflow for an "aesthetic" update.
Is anyone working on an option to revert to a useful color scheme?
Nachricht 20 von 20
Nicht anwendbar
@jeff_strater
This change has been around for months now, is there any action expected on it? I find it very strange that the sketch colors were altered to be clearly less visible.
Using the default body appearance in Photo Booth there isn't much contrast with unconstrained sketches or projected lines:
In component color cycling, some configurations make the sketches essentially invisible:
In one of your earlier posts you mentioned there may be a way to adjust sketch colors with an XML file, if that is possible can you please detail how I can do that?
I'd also appreciate this getting brought up with the sketch team again. Even if reverting the sketch colors isn't going to happen, adding an option like "High Visibility Sketches" which switches to higher contrast colors or thicker lines would be useful.
Thanks.
