New components not showing properly on updated drawing
Roland.Kalamar
Message 1 of 59
Roland.Kalamar
Hi all,
I have an urgent task of creating "as-built" drawings based on my earlier drawings. I have the following problem:
I have some new components in the assembly that were added later than when the drawing was originally created from the assembly. (New components as well as new sub-components of existing components).
After updating the drawing the added parts should be shown, but to my surprise this is not the case (either shading is shown but no contours, or nothing at all.)
Also it is the same for new features of existing components.
I don't know what is going on, doing all the drawings again from scratch instead of just updating existing ones is not an option.
Please share if you have experienced this or if you have any solution or ideas at least.
Replies (58)
Message 41 of 59
toffypops
Sent you the generated drawing file by mail, as well as the info below.
[GPU Information]
GPU Device: NVIDIA GeForce RTX 2080 SUPER
GPU RAM: 8064 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 531.68
GPU Driver Date: 04/14/2023
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Message 42 of 59
toffypops
Another example. Just zooming makes objects vanish.
I tried changing NVIDIA driver from gaming version to studio-version, without anything changing.
If i try to print the drawing, the objects are not visible when printing so it seems the link to the components get broken, or the cache for invisible objects are cleared when zooming. For me this feels like Fusion is unable to maintain it's draw-buffer for objects that originated from linked-in-components from f3d files, when you zoom in and out, where the links have been broken. Usually an update from the project fixes the view of all other project files.
[video]
Message 43 of 59
vafolabi566
Observer
Observer
Hi @ClintBrown3D @tarkeshwar.shah
I am currently on the latest version of fusion 360 and have started experiencing this issue.
Message 44 of 59
liang_chen
Hi @vafolabi566 ,
We can't reproduce this issue in the test case in our side. is there any specific dataset or workflow leads to this issue ?  Pls share the dataset and workflow with us for inveistigation. (Right click drawing file in data panel -> Share link -> Share the link of drawing file and allow to be downloaded.)
If it is confidential and can't be shared in public, you can share the files in mail . My mail is 'liang.chen@autodesk.com'
Fred Chen
SQA Engineer
Quality Assurance Team
Message 45 of 59
toffypops
I already shared all files TWICE to your employees!
Message 46 of 59
willpT3BP7
Observer
Observer
This has been a big problem for me as well recently.  The posted work around only works for one component at a time, each subsequent suppress / unsuppress breaks the one that I had just fixed.  However, I believe I have another work around that is also quicker.  I duplicated the sheet and deleted the old sheet and the model is displaying as it should.  Hopefully this is helpful to others because I have lost a lot of time due to this bug.
Message 47 of 59
dbeltrang
Still having this problem. I tried the duplicate trick and it does not work for me. But today I realized something new. It depends on the style. So chosing "sombreado", closing, chosing "aristas", closing worked for me.
Message 48 of 59
leso96
I just had this error occur in the most recent build. I went back to a file and boleaned some bodies, and in previously draw drawings the new body did not show (it does however show on newly placed views). I solved this by duplicating the sheet and on the new sheet changing the appearance of the view, then all the new bodies showed and i could delete the original sheet.
Message 49 of 59
natzoo
I am having the same issue. I tried toggling as many menus as possible, but nothing fixed it. If I create a new base view, the part is visible. However, that would require me to redo over 50 pages of drawings.
The component is made visible in the sheet, but it does not have lines in the drawing:
@ClintBrown3D @Roland.Kalamar, the file is sensitive. Can I directly email it?
I triggered this bug by "Creating component from body". After I had done this, I saved, and updated my 2D drawings. After that, the part outlines stopped showing up.
Thanks for the help!
Message 50 of 59
Pramod.kadam
Hi @natzoo ,
Apologies to hear that you are facing an issue. Please share the file to Pramod.Kadam@autodesk.com
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 51 of 59
leso96
Try duplicating the sheet(s) then changing the shading type on the
duplicate. That should work and not take too long. When done you can remove
the original sheet.
Message 52 of 59
erich_krug
It appears this is issue has returned in Fusion 2024 - 2.0.20981. I encountered this exact same problem and had to use the provided workaround (suppressing and unsuppressing components) to resolve it.
Message 53 of 59
awilliamwright
I am currently having this problem, and no workarounds work (not suppress/unsuppress, not tweaking the design and updating, not hiding then revealing, not duplicating the sheet and changing shading type).
You can see the component if I switch view mode from Visible Edges to Shaded, but they're transparent (I can see the component it contains, through it). I included screenshots of this.
Message 54 of 59
jhackney1972
You really need to create a new Forum topic and not dredge up something so ancient.  Anyway, please attach your MODEL only so the Forum users can take a look, create their own 2D Drawing  and see what is up.
John Hackney, Retired
Message 55 of 59
awilliamwright
Posting on a thread like this provides immediate context and shows that this is a problem that has not been properly fixed. Also, I am not inclined to share my projects publicly, much preferring to securely share the project with someone at Autodesk (which I have done many times in the past). I do not appreciate the implied tone of your reply, which is unprofessional and presupposes I don't know what I'm doing.
Message 56 of 59
liang_chen
Hi @awilliamwright ,
Sorry to hear that you meet this issue.
In internal backlog, there is a similar issue reported, and DID is FUS-167022.  This kind of issue could be related to specific dataset, and I could suggest you to share the dataset with us for issue logging and investigation. Ususally, we need to log individual issue by dataset.  You can share the link of dataset to 'liang.chen@autodesk.com', and the datatset will Only be used for internal investigation.
If you have any contact of local product support, you can also raise up this issue to them.  It will be helpful for issue prioritizing and fixing.
Thanks for your support and patience.
Fred Chen
SQA Engineer
Message 57 of 59
awilliamwright
Links sent. And thank you!
Message 58 of 59
liang_chen
Thanks for sharing the dataset. Reply the details in Email.
Fred Chen
SQA Engineer
Message 59 of 59
awilliamwright
Thanks to Fred, I was able to hobble together a sort of working drawing from my project. So the crisis is over for now.
It seems that I had two bodies with bad geometry (which is why they didn’t show up), and in both cases it was caused by fillets. In one case I was able to unstitch the body, delete the Etcher-esc surface causing the problem, then stitch it back together and it was fine.
The other body was too messy for me to be able to hunt down the offending surface, so I had to roll the history back before everything broke in order to get the drawing to work.
in the future, I’ll know what to look for.
