Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
New add-in to export and import tube geometries used with CNC bending machines (XYZ and LRA/YBC).
6 REPLIES 6
JeromeBriot
1503 Views, 6 Replies
JeromeBriot
Tube Bending Data Exchanger is an add-in that allows Autodesk® Fusion 360™ to export and import tube geometries used with CNC bending machines (XYZ and LRA/YBC).
Create the tube geometry with Fusion 360 and export bending data in XYZ and LRA/YBC format. Or import XYZ data to automatically create the tube geometry in Fusion 360. The tube segment must start and end with a straight segment of tubing, and must be a constant diameter. Straight segments must alternate with bent segments.
The add-in uses text files that you can easily modify by hand and from which you can easily copy/paste data.
The add-in manages unit conversion: millimeter, centimeter, meter, inch and foot. You can design the tube in millimeters and export the data in inches for example. Or import data in centimeters from data specified in inches.
The add-in supports hollow tubes by setting outer diameter value and wall thickness value.
Sample files are provided in the installation folder of the add-in.
Purchase and download the add-in on the App Store:
6 REPLIES 6
JeromeBriot
in reply to: JeromeBriot
JeromeBriot
New version available (1.1.0):
  • Fix a bug when a tube contains too many faces
New version available (1.2.0):
  • Fix a bug when a tube contains not enough segments
New version available (1.2.1):
  • Activate "Run on Startup" feature
JeromeBriot
JeromeBriot
New version available (1.3.0):
  • Fix a bug when a tube contains two consecutive bent segments
  • Fix a bug when a tube doesn't start or end with a straight segment
  • Fix some typos
New version available (1.4.0):
  • Accept tube with faces that have more than two edges
  • Refactor Python code
  • Fix some typos
JeromeBriot
JeromeBriot
New version available (1.5.0):
  • Fix a bug with wrong outer diameter computation in import/export
  • Fix a bug with wrong wall thickness computation in import/export
  • Add an error message when a tube contains 180 degree bends
  • Add support for French language
  • Refactor import dialog
  • Improve first install message
New version available (1.6.0):
  • Fix a bug with output XYZ data when path is reversed
JeromeBriot
JeromeBriot
New version available (1.7.0):
  • Fix a bug with faces that have 4 edges
New version available (1.8.0):
  • Add developed length computation
JeromeBriot
JeromeBriot
New version available (1.9.0):
  • Support CSV and XLSX format (export only)
JeromeBriot
JeromeBriot
New version available (1.9.1):
  • Fix a bug with Turkish language
