Need help with T-splines enhancement
Message 1 of 17
Hi there 🙂
1) I didn't find any information, how to change curvature of the splines. For example, I need to make a spline less curved. Or change curvature to another direction to get smooth line.
2. There's something confusing with my model. When i'm trying to add some edges at the back of my car, there's happen strange things that I don't understand. After that I can't even save model, because it has some problems with intersections, although in box mode everything seems ok.
Replies (16)
Message 2 of 17
SaeedHamza
Could you explain more what exactly your problem is, I noticed that you're talking about these 2 parts of your model, but don't really understand what your problem is
Saeed Hamza
Message 3 of 17
Well, there're two different problems. First one is more common: changing of curvature I do need not only in this model. But second problem is only for that model: adding of the edge in the back makes smooth angles sharp.
Message 4 of 17
SaeedHamza
Working with the sculpt environment is like a craft, can't really explain it by words, you need pictures like examples, because you can't predict what is going to happen to your model until you do it
So for a faster solution, I recommend you post a picture or something like that because what you're asking about is so general and not specified
Saeed Hamza
Message 5 of 17
Illustrations at the first message is not enough?
Message 6 of 17
Can I change curvature that way, or it is imopible?
Message 7 of 17
SaeedHamza
Of course you can, but it depends on how the curvature is
As I said, it's a general question so you need a picture to show exactly
what you mean
Saeed Hamza
Message 8 of 17
SaeedHamza
what you mean
Saeed Hamza
Message 9 of 17
Can you, please, list all methods? I face that problem frequently. And how would you act Снимок экрана (60).pngUntitled-1.pngat pictured case?
Message 10 of 17
SaeedHamza
sorry I didn't see the picture you posted because I was replying from a phone
Try deleting the faces around the curve and then use merge or bridge to connect them in a better result
Regards
Saeed Hamza
Message 11 of 17
TrippyLighting
Exactly! It is hard to explain these things without being able to show them at the same time in a screencast.
Message 12 of 17
TrippyLighting
I have to say that I fail to see the magnified views in your screenshots in the model.
However, what I do see in your model is that you use the patch environment to patch openings in the T-Spline. That is a bad idea. Really bad!
If you try to fillet that I can guarantee that this is likely to fail at some point.
It's better to fill that hole  that using the T-Spline environment.
Message 13 of 17
SaeedHamza
Peter it took me a minute to realize that you mean the PATCH environment Smiley Very Happy
Saeed Hamza
Message 14 of 17
TrippyLighting
Oops. I swear this keyboard randomly swallows letters!
Message 15 of 17
SaeedHamza
Watch this screencast please, I tried to explain your problem :
Saeed Hamza
Message 16 of 17
Oh, okaay
Message 17 of 17
SaeedHamza
Here are some tips to help you work with the sculpt environment, I hope it helps
Best of luck
Saeed
Saeed Hamza
