Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Need Help With Slicing
1 REPLY 1
G-Qu
174 Views, 1 Reply
I'd like to slice these doors to 3D print- cut down the middle, and the rest in pieces according to the planes.  At the moment they are mesh bodies- not sure if/how I can convert them to make them easier to work with.  Yes, they are indeed to spec!  Can mesh bodies be sliced?   Not sure how to proceed because when I attempt to make the cuts, Fusion freezes and crashes.  Any suggestions?  Thanks!
1 REPLY 1
davebYYPCU
in reply to: G-Qu
After loading the file,
Go to Mesh workspace,
Use Modify > Plane Cut, select keep both side.
Might help...
