I'd like to slice these doors to 3D print- cut down the middle, and the rest in pieces according to the planes. At the moment they are mesh bodies- not sure if/how I can convert them to make them easier to work with. Yes, they are indeed to spec! Can mesh bodies be sliced? Not sure how to proceed because when I attempt to make the cuts, Fusion freezes and crashes. Any suggestions? Thanks!
Solved by davebYYPCU. Go to Solution.
After loading the file,
Go to Mesh workspace,
Use Modify > Plane Cut, select keep both side.
Might help...
