Need help with sketching around a corner (project and pic added)
takacosu
takacosu
This might seem like a easy problem but Im having problems making it work.
Im trying to sketch around a corner and extrude all evenly. I have looked up and watched tutorials on how to extrude on a curved surface but i get problems at the corners.
What I tried was extrude into it and split body. then extrude out on all sides, then extruded the face to match up each side, but when I got to fillet it, it seems like theres multiple edges and throwing off the fillet.
I also tried to project but it didnt seem to work
Is there a better way to do this?
https://a360.co/2GTx4Fg
g-andresen
try it this way:
1. offset plane
2. project/intersect contour
3. edit contour  > path
4. plane along path
5. profile on plane
6. sweep profile along path (option > join)
7. create fillet
profile around edgesprofile around edges
günther
