Stencil to print out
g.poenaru
g.poenaru
Is it possible to add a new plane that intersects with a body and print (e.g. injection ink) this intercection to use it as a stencil?
laughingcreek
probably.  place your plane, create a sketch on the plane, and then do a project/intersect to get a sketch of a cross-section of the body.
if you file/export your .f3d file and share it, or at lest out up some pictures describing what ou want to do you might get more specific help.
g.poenaru
Many thanks, that is exactly what im looking for. With your help i was able to get an cross-section of the body, afterwards I followed this post ( How do I print out sketch? - https://forums.autodesk.com/t5/fusion-360-design-validate/how-do-i-print-out-a-sketch/td-p/5480577 )
