Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Need Help designing a Flat Screw
2 REPLIES 2
nicolas-regel
270 Views, 2 Replies
im trying to reversengineer this flat screw with a flat coil. But the flat coil cant be press pulled in the z direktion so the screws Z dosent go throu the cylinder all the way.
Exampels in pictures
Tags (2)
2 REPLIES 2
etfrench
in reply to: nicolas-regel
Try this:
Another option would be to use the loft command.
Create sketches for both end profiles (center will be higher).
Create a coil with square or triangular section.
Loft the two end profiles using one edge of the coil as a rail.
ETFrench
nicolas-regel
in reply to: etfrench
thank you for reminding me of the split body function, i used it together with the coild function to create this test piece
Technology Administrators
