Need Help designing a Flat Screw
nicolas-regel
nicolas-regel
im trying to reversengineer this flat screw with a flat coil. But the flat coil cant be press pulled in the z direktion so the screws Z dosent go throu the cylinder all the way.
Exampels in pictures
etfrench
Try this:
Another option would be to use the loft command.
Create sketches for both end profiles (center will be higher).
Create a coil with square or triangular section.
Loft the two end profiles using one edge of the coil as a rail.
ETFrench
nicolas-regel
thank you for reminding me of the split body function, i used it together with the coild function to create this test piece
