Named views
Named views
joergen_nilsson
Message 1 of 11
Named views
joergen_nilsson
How do I rotate a view a specified angle around the z-axis before making a new named view?
Replies (10)
Message 2 of 11
g-andresen
this way
günther
Message 3 of 11
Leo_Dyn
Is there a way to get fine grained control of the camera like this, as opposed to actually moving the part?
That'd sure be nice.
Message 4 of 11
jhackney1972
Make the Origin Axis visible.  Create a Construction Plane at Angle using the Z-Axis or any other line or axis to the precise angle you need the view.  Use the Look At option in the navigation panel to view this new construction plane.  Save your named view, and turn off your construction plane and Origin.
John Hackney, Retired
Message 5 of 11
Leo_Dyn
Awesome, thanks for the tip!
Message 6 of 11
joergen_nilsson
The problem I have is really to generate the local z-axis to rotate around. My plan was to first create a plane in an arbitrary direction, then to make an axis perpendicular to that plane. But with no success.
I'm used to other cad-modelers like e.g Spaceclaim/Designspark where you easily can create a local cs in a desired direction.
Message 7 of 11
g-andresen
Show the situation in a screencast and share the file to reply.
günther
Message 8 of 11
joergen_nilsson
Ok, let say I have created a plane like in view1.png. I point out that plane as "look at" and then I want to rotate that view a certain degree like in namedview.png.
Note: Just to show my problem, I created namedview.png just by using my 3d-mouse, but what I am after is to be able to create a similar view with exact figures.
Message 9 of 11
g-andresen
might help
günther
Message 10 of 11
joergen_nilsson
Sorry, I don't really understand what you're doing in the video.
Message 11 of 11
g-andresen
might help?
günther
