Moving or constraining an imported SVG without changing it
JetForMe
JetForMe
Is there a way to group the elements of an imported SVG into a fixed body that can be moved, rotated, and scaled without otherwise changing the SVG? When it's first imported it's fully fixed, which preserves the shape, but doesn't let me move it or align it with other features in the sketch.
I also wish one could set constraints with the nine standard control points (corners and edges of bounding box, center). But if those aren't in the SVG to begin with, it seems there's no good way to accomplish it. Any suggestions?
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
jeff_strater
no, there is no way to make any kind of "rigid group" in sketch.  The best you can do today is to create a selection set of the whole imported SVG, and make it easier to select all the items in that group.
Jeff Strater
Engineering Director
jhackney1972
Since @jeff_strater beat me to the punch, I have attached a Screencast, I had made, to illustrate his answer about Selection Sets.
John Hackney, Retired
JetForMe
Thanks. The selection set will suffice as a workaround, but it's not really a complete solution. Thank you though, I didn't know about them!
