Moving components with ease and accuracy
smallfavor
smallfavor
I've three components that I want to move to the 0 point of the construction plan.  My usual method is to select all the obects and then a center point to be moved to another point.  I can't seem to do this.  I'l like to know why.
SaeedHamza
Could you share the model
Regards
Saeed Hamza
smallfavor
sure!
http://a360.co/2y6vlX8
TrippyLighting
The three components of your pan are in a component group (also otherwise referred to as an assembly).
That assembly has its own origin.
You can simply us a point to point move of that assembly and select the assembly origin as the start point and the top level origin as the target.
SaeedHamza
Here is a screencast
I hope it help you understand the point to point move tool better
Regards
Saeed Hamza
smallfavor
Thanks guys!
smallfavor
Thanks peter!
