tool path???
tool path???
tool path???
Hi all can anyone help me got this far, thanks to your help, can any one tell me how to cut this out. I will tell you what i am trying to do, I can cut all the pockets ok but can not do the contour and the shaping. What i need is to have the stock block to hold the part with the two 8mm holes top and bottom and have two large tabs top and bottom 25 x 6mm. Every time i try, it removes the stock so no holding parts tried everything i can think of don't know were to go from here thanks Dave.
etfrench
One way to do this is to add a fixture (or 2) containing the registration holes.  Add the fixture(s) in the Setup dialog.
ETFrench
Hi thank you will give it a try at the weekend. Thanks again Dave.
Hi sorry for the slow reply can only work on this at weekends. Thanks for your help, it worked thank you all the best Dave.
