Move an origin plane
j9lemmon
j9lemmon
I have a 2nd Origin Plane in a different position than the main origin plane. I did not intend this. This 2nd plane appeared yesterday after working on the design for many days. Apparently, I mistakenly moved this 2nd origin plane. Screenshot attached.
Is there a way to move this 2nd Origin Plane to the same location as the main plane?
Thanks in advance.
alessandro.gasso
Please, can you share the file?
Thanks and regards,
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
g-andresen
Take a look at your components.
Each has its individual origin. This changes with the position of the component.
You´ll see it if you switch origins on & off.
günther
laughingcreek
If you activate your top level component so youi can see the entire timeline, do you have a capture position feature?  if so delete it.
j9lemmon
Thanks @laughingcreek
A Capture Position Feature in the Timeline was the problem.
Huge help!
