I have a 2nd Origin Plane in a different position than the main origin plane. I did not intend this. This 2nd plane appeared yesterday after working on the design for many days. Apparently, I mistakenly moved this 2nd origin plane. Screenshot attached.
Is there a way to move this 2nd Origin Plane to the same location as the main plane?
Thanks in advance.
Solved by laughingcreek. Go to Solution.
Please, can you share the file?
Thanks and regards,
Take a look at your components.
Each has its individual origin. This changes with the position of the component.
You´ll see it if you switch origins on & off.
günther
If you activate your top level component so youi can see the entire timeline, do you have a capture position feature? if so delete it.
