Move along one axis with snapping
Message 1 of 23
Hi! Is that possible in Fusion 360 to move along some certain axis but with snapping enabled? Look at screen record attached. Here I'm showing how simple it realized in SketchUp and trying to figure out how to do something the same in Fusion 360. For example, I need to move my body along "X" axis and want it to be snapped to another body by choosing reference points. I know I can use "move" command with "point to point" or "align" but it doesn't do such kind of job or maybe I'm wrong?. This should be basic things but I don't know what is the easiest way to do it.
Replies (22)
Message 2 of 23
Also, I'm not sure how it is possible to align such objects as sphere if Fusion 360 doesn't show any bounding box of the selected object. For example what if I decide to align one of the sphere's bounding box corner to the box's corner?
Message 3 of 23
davebYYPCU
Fusion does not use bounding boxes for geometry, it uses it’s native objects.
To move with snap, the destination point must exist.
Message 4 of 23
Sorry, I'm mostly SketchUp user and now decided to learn F360 and before writing this topic I've watched a lot of tutorials and read the documentation. So I like F360 because of its simplicity. I'm still doing some practices and generally, everything I need I can already do in F360. But today I've realized that there is something I missing up with F360 workflow as long as I can't do these basic things as accurate moving (aligning) with snapping shown above. I tried to find something like "F360 moving/aligning tricks, etc." but no success that's why I decided to ask for some help here. Thanks!
Message 5 of 23
g-andresen
In Fusion, the Joint-tool is designed to align and snap.
günther
Message 6 of 23
TheCADWhisperer
Attach an example file of something that you have completed in Fusion 360.
Message 7 of 23
davebYYPCU
Honestly your video did not do as you asked That rear white corner is not aligned to anything.
You have mentioned move point to point, destination must exist.
you have not mentioned sketch.
Fusion is sketch based parametric modeller.
Using primitives in Fusion, are well, primitive.
Snap alignment points are provided in Fusion, with correct tools, Align and Move, or Joints.
As for the Sphere, snap the centre point to your (Object) with radius Offset.
Might help....
Message 8 of 23
Why not?) I need a body to be moved along only one axis while reference points appearing and could be snapped to each other and that can be seen on the screenrecord.
Message 9 of 23
  1. There is nothing to share indeed. I mean that after each portion of information about F360 I was trying to do some kind of checking “exams” for myself. Something like “ok, now you know how this or that tools work in F360 so try to recreate something you did earlier in sketchup” 😁 And of course I didn’t do full projects and save it, it was just some checking tasks  where I could fail by my suppose having no idea how to do it in F360. I found very usefully functionality with F360 sheet metal and got some questions about it. I’ll share some file later where I need some help with accuracy results I got after making some body bent.
Message 10 of 23
@TheCADWhisperer Hi! Please, look at my record. Here is a part of what I'm getting some problems with accuracy results when making flanges. At the beginning of the video, I'm showing my 1st simple variant where I use "thicken" command what means I only need to add some fillets to some needed edges. But at the end of the record, I'm showing how bending makes some inaccurate results in the bottom. Here is also .f3d file attached.
Thanks!
<iframe width="640" height="650" src="https://screencast.autodesk.com/Embed/Timeline/4d2de08b-d6e1-4665-90c1-5d653f0709bb" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 11 of 23
jhackney1972
I fixed your Screencast to show on the forum.
John Hackney, Retired
Message 12 of 23
Here is screencast
Message 13 of 23
shahriarsifat1802164
You can use move/ copy or align tools to do this kind of stuff.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 14 of 23
Again if there any required assembly stuff you can easily make joints components as you need.
RUET
Thank you.
Message 15 of 23
Yes, I understand it and know I can manually align it to bottom plane, etc. But I just interesting in why is this happening in this case while using flanges command. Where is my fault or what.
Message 16 of 23
TheCADWhisperer
Thank you.
I don't understand anything that you have written.
I understand geometry better than words.
Can you Attach your *.f3d solution here?  (This is a binary yes/no question.)
Message 17 of 23
TheCADWhisperer
@Anonymous wrote:
Please, look at my record. Here is a part....
@Anonymous
Where are your sketches?
The foundation of Fusion 360 Sheet Metal is parametric sketching.
You appear to be attempting to build without a foundation?
Message 18 of 23
This was a mesh imported from SketchUp and then converted to surface here in F360 using 'mesh to BRep" command.
Message 19 of 23
TheCADWhisperer
SketchUp geometry is rubbish.
Can you Attach the orginal *.stl file from SketchUp?
Do you want to learn Fusion 360?
You should have parametric sketches similar to Attached file.
This isn't 100% correct yet, but my initial attempt to understand your true Design Intent.
Message 20 of 23
Yes, here is .stl file.
