Move along one axis with snapping
Message 1 of 23
Hi! Is that possible in Fusion 360 to move along some certain axis but with snapping enabled? Look at screen record attached. Here I'm showing how simple it realized in SketchUp and trying to figure out how to do something the same in Fusion 360. For example, I need to move my body along "X" axis and want it to be snapped to another body by choosing reference points. I know I can use "move" command with "point to point" or "align" but it doesn't do such kind of job or maybe I'm wrong?. This should be basic things but I don't know what is the easiest way to do it.
Replies (22)
Message 21 of 23
TheCADWhisperer
See the Attached file...
Message 22 of 23
TheCADWhisperer
The two bottom panels were not planar.  This was easy to discover by simply attempting to start a new sketch on these panels (can only start a new sketch on a planar geometry).
The two side panels were not co-planar. This was a more complex issue to find. If you leave them in and patch the opening and Stitch - you will observe a boundary that should not be there.
Message 23 of 23
Thanks! now I see what was causing it.
